 Tēma: CLK (W208) 320
AtbildeAtbilde saņemta: 15. Maijs 2013, 15:50
Pievienojies: 13. Maijs 2013, 19:52
Atbildes: 1
Atrašanās vietas: cesis
Mašīna: MERCEDES CLK320
Ja interesē zvanat 28748273 . Visas daļas jaunas.
409835110 BBT Ignition Leads 2.GB. 40 ls./kompl. (sveces vadi)
417220280 Bosch ABS Sensor 2.GB. 60 ls./gb. (abs sensors)
413220190 Bosch Ignition Coil 6.gb. 50 ls./gb. (aizdedzes spole)
402220270 Bosch Starter 3.GB. 100 ls./gb. (starteris)
434220140 Bosch Air Flow Meter 3.GB. 90ls./gb.(gaisa masas meritajs)
635220380 Sachs Shock Absorber (Rear) 2.GB 50ls./gb. (amartizators aizmugurejais)
635220470 Sachs Shock Absorber (Front) 2.GB 50ls./gb. (amortizators priekshejais)
478220710 Hella Rear Lamp (Left Outer,Right Outer) 90ls./kompl.(miglas lukturi kreisais,labais)
219220120 Heater Motor 1.GB. 70ls./gb. (silditaja motors)
710221975 Denso Lambda Sensor 2.gb 40ls./gb. (lambdazonde)
VEMO Accelerator Sensor 1.GB. 70ls./gb. (akseleratora sensors)
419220120 BBT Camshaft Sensor 2.GB. 45ls./gb. (Sadales vārpstas sensors)
Vemo Column Switch 1.GB. 40ls./gb. (sledzis gaizmaam un logu tiritajiem)
503220150 Hengst Fuel Filter 2.GB. 20ls./gb. (degvielas filtrs)
10122035e Textar E-Pad 40ls./kompl (aizmugurejais bremzu klucu kompekts)
10122027e Textar E-Pad 45ls./kompl (prieksejo bremzu klucu komplekts)
101220028 Pagid Brake Pads 16ls./kompl (aizmugurejais bremzu klucu komplekts)
101220278 Pagid Brake Pads 25ls./kompl (prieksejo bremzu klucu komplekts)
