 Tēma: W203 sport coupe priekšējais lukturis. 2002.gads.
AtbildeAtbilde saņemta: 19. Augusts 2019, 10:22
Pievienojies: 29. Septembris 2017, 20:51
Atbildes: 58
Mašīna: w203
Labdien! Problēma tāda, kad mainot tālās gaismas lampiņu esmu izspiedis ārā luktura atstarotāju un tagad viņš ir nokāries uz leju un kustās. Vai var viņu kaut kādā veidā nofiksēt atpakaļ. Ārzemju forumos bija šāds variants vai tas ir aktuāls-
If you try to raise the headlight too much (unscrewing), the projector will come apart from the leveler and start flopping around (obviously at this point it doesn't matter which way you turn the screw, it won't adjust anything.
If you can wobble the bulb (and projector) up and down, you have this issue.
To fix this you just simply pop off the cover to access the bulb.Grip the bulb and pull upwards on it (this in turn causes the projector to aim downwards). While holding the projector in this position, start turning the adjuster screw clockwise until the projector catches onto the leveling gear. You'll know because you wont be able to wobble the bulb up and down anymore.
