 Tēma: JBL
AtbildeAtbilde saņemta: 02. Augusts 2009, 19:16
Pievienojies: 17. Jūlijs 2009, 17:59
Atbildes: 27
Prodaju JBL akustiku.
Cena dogovornaja.
JBL P 1222 Attēls
JBL P 1222 Attēls
V korpuse.
SPECIFICATIONS
General
Power Handling, RMS 400 Watts
Power Handling, Peak 1200 Watts
Sensitivity 97dB
Mounting Depth 6-3/4"
Cutout Diameter 11-1/16"
Impedance Dual 2 Ohms voice coils can be wired to deliver either a 1 ohm or 4 ohm load
_________________________________________________________________________________
JBL Px600.2 Attēls
SPECIFICATIONS
General
CEA Rated
Click here to learn about the new CEA2006 Amplifier Standard.
Power Output 180 watts RMS x 2 channels at 4 ohms
and ≤ 1% THD + N
290 watts RMS x 2 channels at 2 ohms,
14.4 V supply and ≤ 1% THD + N
Signal-to-Noise Ratio 79.5 dBA (reference 1 watt into 4 ohms)
Dynamic Power 714 watts at 4 ohms
Effective Damping Factor 6.274 at 4 ohms
Maximum Input Signal 5.95 V
Frequency Response 10Hz – 97kHz (-3dB)
Maximum Sensitivity 264 mV
Output Regulation .056 db at 4 ohms
Dimensions (H x W x D) 2-9/16" x 17" x 12-1/4"
JBL Px300.4 Attēls
SPECIFICATIONS
General
CEA Rated
Power Output 123.5 watts RMS x 4 channels at 4 ohms
and ≤ 1% THD + N
358 watts RMS x 2 channels at 4 ohms, 14.4V supply and ≤ 1% THD + N
Signal-to-Noise Ratio 76.64 dBA (reference 1 watt into 4 ohms)
Dynamic Power 194 watts at 4 ohms
Effective Damping Factor 6.383 at 4 ohms
Frequency Response 16.6Hz – 500kHz (-3dB)
Maximum Input Signal 5.9 V
Maximum Sensitivity 250 mV
Output Regulation .39 dB at 4 ohms
JBL C508gti Attēls
SPECIFICATIONS
General
Power Handling, RMS 125 Watts
Power Handling, Peak 500 Watts
Frequency Response (±3dB) 58Hz - 21kHz
Sensitivity (2.83V @ 1m) 88dB
Impedance 4 Ohms
Crossover Frequency(ies) 3.5kHz, 24dB/oct
Mounting Depth 2-3/8" Woofer, 1-1/8" Tweeter
JBL P522 Attēls
SPECIFICATIONS
Warranty 1 Year
General
Power Handling, RMS 55 Watts
Power Handling, Peak 165 Watts
Sensitivity 89dB
Frequency Response (±3dB) 55Hz - 23kHz
Mounting Depth 2-3/16"
Impedance 4 Ohms
Ukogo est somnenie po povodu sili JBL P1222 proshu video. Links . Smotret dokonca
Efekt s dvumja konecno no s odnim zato stekto neviletit.
Takze Kander 1.0 farada , provoda , predoxranitel OELBAH. i koe kakie meloci dlja instaljacii.
Pēdējo reizi laboja Serjoga26 - 03. Augusts 2009, 11:52, kopā labots 1 reizi.
 Tēma: JBL
AtbildeAtbilde saņemta: 02. Augusts 2009, 19:46
Kakije melo4i po instalacii estj?
 Tēma: JBL
AtbildeAtbilde saņemta: 03. Augusts 2009, 00:09
Atbildes: 27
Provada , akusticeskie filtri, silovie provada (OELBACH), Vprincipe vsjo dlja togo ctobi vsja akustika rabotala i vsjo ctobi ejo ustonovit.
Pēdējo reizi laboja Serjoga26 - 03. Augusts 2009, 11:48, kopā labots 1 reizi.
 Tēma: JBL
AtbildeAtbilde saņemta: 10. Augusts 2009, 08:45
Atbildes: 27
