 Tēma: Pardodu jaunus PH Pavilion loptopus, vai kadam interese?
AtbildeAtbilde saņemta: 31. Janvāris 2009, 13:01
Jauns HP Pavilion dv3-1075us.
Entertainment-centr ic notebook PC with fluid, modern lines in bronze and chrome with argyle-like patterning; widescreen 13. 3-inch LCD
2. 1 GHz AMD Turion X2 Rm-72 dual-core processor, 320 GB hard drive, 4 GB RAM (8 GB max), LightScribe dual-layer DVD drive
Draft-N Wi-Fi (802. 11a/b/g/n); Gigabit Ethernet; ATI Radeon HD 3200 graphics (up to 1982 MB total)
Connectivity: 3 USB (with 1 shared eSATA), 1 Hdmi, 1 Vga, ExpressCard 54/34, 5-in-1 memory card reader
Pre-installed with Windows Vista Home Premium with SP1 (64-bit version); includes remote control
Processor, Memory, and Motherboard
Hardware Platform: PC
Processor: 2. 1 GHz AMD Turion 64
Number of Processors: 2
Ram: 4000 MB
RAM Type: Ddr2 Sdram
Operating Systems: Windows Vista Home Premium 64 bit
Startup Operating System: Microsoft Windows Vista Home Premium 64 bit
Operating System Licenses Included: Microsoft Windows Vista Home Premium
Platform: Notebook PC
Expansion Ports: 1 - Express Card Slot/34
Display Type: Wxga with High-Definition BrightView
Viewable Screen Size: 13. 3"
Hard Drive
Type: Serial ATA
Size (Lwh): 31 cm, 23 cm, 2. 6 cm
Weight: 3. 1 kg
Cena: 465 ls
http://www.ss.lv/msg/ru/electronics/com ... jRVw=.html
Jauns HP Pavilion dv4-1120us.
• 14.1-inch Diagonal WXGA High-Definition HP BrightView Widescreen Display, 1280 x 800 resolution
• 2.00 Ghz Intel Core 2 Duo Processor T5800 with 2MB L2 Cache
• 4096MB DDR2 System Memory (2 Dimm), 250GB (5400RPM) Hard Drive (SATA), Intel Graphics Media Accelerator 4500MHD (shared) with up to 1759MB Total Available Graphics Memory
• LightScribe SuperMulti 8X DVD±R/RW with Double Layer Support, Wireless LAN 802.11a/b/g/n WLAN
• Genuine Windows Vista Home Premium, dims in inches: 13.15 in (L) x 9.45 in (D) x 1.34 in approx., 5.18 lbs
• Hardware Platform: PC
• Processor: 2.0 GHz Intel Core Duo
• Number of Processors: 2
• RAM: 4000 MB
• RAM Type: DDR2 SDRAM
Hard Drive
• Size: 250 GB
• Manufacturer: Portable
• Type: Serial ATA
Ports and Connectivity
• Modem: Fax / modem
• Size (WH): 24 cm, 10.9 cm
• Weight: 3.9 kg
Cena: 465ls
http://www.ss.lv/msg/ru/electronics/com ... lSFs=.html
Новый HP Pavilion dv9700.
Процессорная технология Intel Centrino Duo
Процессор Intel Core 2 Duo T7500
2, 20 ГГц , Кэш-память 2-го уровня 4 Мб
Адаптер беспроводной связи Intel Pro/Wireless 3945ABG
Microsoft Windows Vista Home Premium (32-разрядная версия)
Стандартное Озу
4096 Мб
Максимальная память
Поддерживает до 4 Гб памяти DDR2
Жесткий диск
Внутренний накопитель на жёстком диске
320 Гб (2 x 160 Гб)
Контроллер жёсткого диска
Жёсткий диск SATA
Скорость привода жёсткого диска
5400 об/мин
Оптический диск
Super Multi DVD Writer (+/-R +/-Rw) с поддержкой двухслойной записи и технологии Lightscribe
Устройство с картой памяти
Встроенное устройство чтения карт памяти "5 в 1" для карт Secure Digital, MultiMedia, Memory Stick, Memory Stick Pro или xD Picture
Средства коммуникации
Модем
Высокоскоростной модем 56K
Сетевой интерфейс
Встроенный 10/100/1000 Gigabit Ethernet LAN
Беспроводные технологии
Возможность бескабельной работы
Беспроводное подключение к сети с помощью технологии Bluetooth
Внешние порты ввода-вывода
3 порта USB 2. 0, 1 разъём Hdmi, 1 порт Vga, 1 разъём Rj11 для модема, 1 разъём Rj45 для сети Ethernet, ТВ-выход S-video, 2 выхода для наушников, 1 вход для микрофона, 1 Ieee 1394, инфракрасный порт пульта дистанционного управления, кабельный разъём для док-станции
Интерфейс видеозаписи
Интерфейс Ieee 1394 Firewire
Гнёзда расширения
Один слот ExpressCard/54 (поддерживает также ExpressCard/34)
Дисплей
Размер дисплея
Широкоэкранный монитор Wxga+ BrightView высокой чёткости с диагональю 17"
Разрешение экрана
1440 x 900
Видеоадаптер
Nvidia GeForce 8600M GS
Видео-ОЗУ
Общий объём графической памяти до 1791 Мб и 512 Мб выделенной
Панель управления
Программа для воспроизведения мультимедиа HP QuickPlay со специальными элементами меню, кнопками управления музыкой и DVD
Эргономические функции
Встроенное устройство считывания отпечатков пальцев
Web-камера
Hp Pavilion WebCam со встроенным микрофоном
Пульт дистанционного управления
Мобильный пульт дистанционного управления HP
Внутреннее аудио
Встроенная звуковая карта 16 бит, совместимая с 3D Sound Blaster Pro
Громкоговорители и микрофон
Динамики Altec Lansing
Клавиатура
Полноразмерная настольная клавиатура (с отдельным полем цифровых клавиш)
Указывающее устройство
Сенсорная панель с кнопкой включения/выключени я и выделенной полосой вертикального скроллинга, кнопки регулировки громкости и отключения динамика, 2 кнопки быстрого запуска
Вес
3, 55 кг
Размеры (Ш x Г x В)
28, 50 см (L) x 39, 60 см (W) x 3, 16 см (мин. ) / 4, 18 см (макс. )
http://www.ss.lv/ru/electronics/compute ... TeF4S.html
Ja ir interese zvaniet pa talr.: 27115317
AtbildeAtbilde saņemta: 31. Janvāris 2009, 13:02
Sorry, pedejais links ir sis:
http://www.ss.lv/msg/ru/electronics/com ... rRlo=.html
